Damn - wish i knew this when I was hunting around for a power supply that could run my M9 and Variax box at the same time (both AC). I ended up with Cioks AC10
Trading feedback here
Yes the M9 can run on DC given sufficient current.
The doubler you linked to on GAK is actually a voltage doubler, which will take two 9V outputs to make 18V - that is not the one you want.
The Voodoo current doubler has a green barrel on one side.
This video from TrueTone has the M9 running on DC, but they said it only actually draws 350ma (about 12 minutes in)
You may also end up needing an adaptor to convert the size as well - I think the M9 has 2.5mm power input, not the typical 2.1mm
https://youtu.be/8q0YrwWhR_Y
