PTP Marshall JTM45/JMP, KT66's Clone
Jim54Jim54 Frets: 244
edited May 2018 in Amps £
Had this amp custom made for me a few years back by a fella who used to frequent either here or the old music radar forum, Pete (think it was 'Moon Amps' or something).
It's a point to point hand wired JTM45 with a few additions:
KT66 power tubes.
Copper cap solid state and valve rectifier (switchable).
A JTM45/JMP switch that changes the tone stack somehow to make it more similar to that in a JMP100 (front panel switch).
PPIMV which can be switched out (front panel switch).
2 speaker outputs (switchable 4, 8 and 16 ohms)
Gold plexi faceplate and Marshall knobs, blonde Fender tolex.
Cab dimensions - Length 20.5 inches, Height 8.5 inches, Depth 9 inches.
The only negative is the quality of the cab construction is not best but adequate for the job. The tolex is in great condition though.
It had a white Marshall nameplate on it but this has been removed
£500.  £400.  Can be collected from near Stockport.
  • Jim54Jim54 Frets: 244
    Bump.  £450 and it's yours.
  • TimmyOTimmyO Frets: 7412
    I had an amp Pete built for a few years - gigged it - sounded great.
    His name is Peter Skelton and he went by New Moon Amps.
    I believe he moved to the USA and is starting up a brewery!
    Red ones are better.
    That's the fella, thanks TimmyO.  Best of luck to him in the US.
    Bump.
    Bump.  Down to £400.
    Bump.
  • strtdvstrtdv Frets: 2438
    Interesting amp. Is the chassis standard Marshall JTM45 size?
    That's turret board BTW, not PTP (not inferior, just different)
    Thanks for the correction bud.  It's a smaller footprint, modelled in size on a Cornell 18/20 I used to have (but a bit higher to accommodate the KT66's.
