SOLD MISSION GEMINI STEREO 2 x 12 (MINT) FRFR POWERED CAB only £875 !
FS: MISSION GEMINI STEREO 2 x 12 (MINT)
THE ROLLS ROYCE OF FRFR FOR GUITAR
If you want to hear your Kemper, Helix or Axe FX at its very best, this is unique not just because the stereo will fatten and expand your sound, but because the EMPOWER blend switch is specially designed to emulate the response of traditional guitar amp / cabs or be run fully Flat response.
The most realistic familiar tones come from dialling back the flat response about 20% and maybe a touch more for those ultra clean Fender Twin / Hi Watt patches that can sound a little bit digital no matter ho much you tweak (works superbly well).
* Looks like Traditional Cab - sounds like trad. cab *
* Can be run as a stereo PA *
* Ultimate Monitor and Back line tool *
* Stereo just brings Delay / Modulation to life *
* USB connections / direct recording out *
* Play jam tracks through it and play at same volume *
Currently a hefty £1,995 (Andertons) and impossible to find pre-owned.
Also comes with professional Caster Spider Flight Case included in immaculate condition (£260 new).
See soundonsound.com for full review
NOW REDUCED TO JUST £875 WHICH IS A COMPLETE BARGAIN
Perhaps it is not very well known but these are the ultimate FRFR set up for any of the modelling devices.........I would go so far as to say that if you have an AXE FX ,Kemper or Helix to go without this is like putting budget skinny tyres on your Porsche Turbo.
