I'm planning to build myself a multi-guitar stand out of wood, and I
want something to cushion the guitars from the wood to avoid scratching
or denting them.
Since I've read scare stories
online about certain materials reacting with certain types of guitar
finish, does anyone have any recommendations as to what is & isn't
sensible to use? Obviously I don't want to rest my guitars on something
to avoid chipping the paint only to ruin the finish in another way.
I
was thinking carpet would be fairly safe, but it might be a bit awkward
to fit - would something like pipe insulation be a good choice?
The
guitars I'll be keeping on the stand will be a Taylor 114 (their site
says finish is "varnish"); Vintage Lemon Drop (they don't specify what
the finish is), and a Fender standard Telecaster (their site says
polyster finish).
Or have I just read too many horror stories and am I overthinking?
That said, your Fender is poly and your Vintage is also likely poly. A 100 series Taylor is also unlikely to be nitro, so you're probably safe. I've personally never encountered a poly finish being damaged by resting it on anything but YMMV.
The Vintage will definitely be polyester. As far as I know Taylor also use polyester, they probably just don’t like to say so because of the negative associations of “poly”... although there is no such thing, other than to guitarists obsessed by “nitro”.
Softwood such as pine would actually be a good choice which is completely safe - if it’s shaped right it won’t risk scratching a guitar. Plain cloth - not strongly dyed - also will be. There are types of foam padding which appear to be, but you need to know what they are.
