Instagram
Ive built a couple of his amps and I’m still here!
Mine still work which is good, a tweed build is next, I'll get parts from modulus too
(formerly customkits)
Seriously, take your time, be a bit organised, use a bit of common sense, follow the instructions, seek (qualified) advice when you’re not sure, show appropriate respect for the mains/HT bits, and you’ll be fine.
None of this stuff is rocket science and the people who put these things together in factories back in the ‘50s, ‘60s, and ‘70s didn’t have PhDs, they just followed a well documented set of procedures and checked their work carefully which is exactly what you’ll be doing if you work from a well designed kit with decent instructions.
I built an Ampmaker SE5a, it was hugely rewarding to do, great fun bringing it to life, and I ended up with a good little amp!
