Suhr DSH+ Black 53mm spacing - previously surface mounted
JMP220478JMP220478 Frets: 421
edited June 2018 in Parts £
Ex Ebay purchase - £35 delivered
i needed a threaded pu to scratchplate mount , thought Id post here before i return it to vendor.
Otherwise will consider trades
  • DefaultMDefaultM Frets: 7321
    You can solder or glue some metal nuts to the existing holes on the pickup ears, so that you're basically adding on a thread for a screw.
    Looks slightly ugly but you won't be able to tell once installed.
    I know its possible but where do I get them to match std pickup screws ?
    The guy that did mine said something about a little craft shop, maybe something to do with airfix models?
  • thetomskthetomsk Frets: 98
    I may well be up for taking this off your hands. What colour is it?
    Black ...
