Best all round guitar
kelpbedskelpbeds Frets: 15
Fancy something that does everything. (with a bias towards metal) Need it to do the heavy stuff, bluesy stuff and poppy stuff (largely for gigging in different bands)
Was considering a Charvel San Dimas as it has coil taps on it (I know they aren't as good as real single coils but better than no coil taps) to get that stratty sound. Or maybe a PRS with coil taps (believe they use a slightly different setup) Also would like some trem system on it but doesn't have to be a floyd (which I'm not massively keen on as they get in the way when you are damping)
The Guthrie Charvel looks fantastic and it has an original flat floyd on. But way too expensive. Must be below 1K. Any thoughts or recommendations?
cheers
  • octatonicoctatonic Frets: 20779
    HSS Strat.
    I am the juice of four limes.
    Trading Feedback
    0reaction image LOL 0reaction image Wow! 9reaction image Wisdom · Share on Facebook Share on Twitter
  • guitars4youguitars4you Frets: 5125
    I'd check out a PRS Custom 24 based on the above info but for under 1K you'd be looking at an S2 version, or hunt around for a USA CE24 model with bolt on maple neck - should get one for under 1 K via a private sale
  • octatonic said:
    HSS Strat.
    End thread.
    3reaction image LOL 0reaction image Wow! 2reaction image Wisdom · Share on Facebook Share on Twitter
  • andy1839andy1839 Frets: 984
    Any of the PRS 513 models, especially the 513 Standard
  • kelpbedskelpbeds Frets: 15
    Got a couple of strats and not keen on the HSS ones (I like a strat to be a strat!) Will check out the PRSs. Are they pretty versatile?
    513 looks perfect but well over my budget!
  • Arktik83Arktik83 Frets: 305
    edited June 2018
    Personally found PRS DGT's are the closest guitar to "ticking all boxes".  The coil taps are great.
    EDIT: Ah shit, sorry didn't realise you said under £1k.  PRS SE EG if you could source one?  Or a Tele custom?
  • meltedbuzzboxmeltedbuzzbox Frets: 8031
    Note choice defines the music not the guitar. If you play Metallica on an es330 or a flying v it will still sound like Metallica.
    Buy whatever you find the most comfortable to play
    0reaction image LOL 0reaction image Wow! 11reaction image Wisdom · Share on Facebook Share on Twitter
  • vincechu89vincechu89 Frets: 27
    Apologies, as i know you have strats, but this @guitars4you  has got to be a super versatile strat: https://www.guitars4you.co.uk/guitars/5512-fender-2015-limited-edition-american-deluxe-mahogany-strat-hss-used/
    mahogany body HSS with S1 switching, and imo looks amazing...  too bad I’m broke or I might have it lol
    a little over your budget though.
  • olafgartenolafgarten Frets: 1468
    Get a good HSS Superstrat with passive pickups. The Ibanez AX Series looks good and is around your budget.
  • maltingsaudiomaltingsaudio Frets: 1035
    Patrick Eggle Berlin pro should be within budget
    www.maltingsaudio.co.uk
  • Phil_aka_PipPhil_aka_Pip Frets: 9761
    No such thing. Its why I keep lots of guitars. IMO the most versatile are ES-335, and SG2000, the latter probably scores because of its coil taps.
    Occasionally a 513 Standard comes up for sale, they're solid mahogany with no flash tops and are about £1k
    But they're quite rare.
  • dindudedindude Frets: 6084
    Ibanez AZ
  • ICBMICBM Frets: 36265
    Any guitar with a couple of different sounds and probably a trem can be used for any type of music. The rest is all down to the amp, effects, image and perception.
    If you really need the in-between Strat sound then you need either a middle pickup, or humbuckers which can be split to the inner coils if they're close enough together - every other sound on an electric guitar is some variation on a neck or bridge pickup tone really.
    Hollowbodies can have a problem with feedback at high gain/volume levels so might be best avoided for metal or hard rock.
    Apart from that just pick something you like the look and feel of...
  • earwighoneyearwighoney Frets: 1735
    Yes to this.  Things like body shape, scale, nut width, neck profile are all personal to the player.
  • Matt_McGMatt_McG Frets: 122
    Yamaha Pacifica 612VFM or 611VFM, depending whether you want HSS or H + P90. You could pick one up second hand well under 400 quid.
    Or any kind of HSS Strat or Superstrat. My own preference would be a classic Strat with a PAF at the bridge, but that's as much because I don't like how superstrats (with possible exception of the Washburn N4 and some Charvels) look.
    Lots to think about chaps, many thanks.
    I agree that the song defines the guitar and that Metallica on a 335 will sound like Metallica. But basically wanted something that sounds as close to my strats and les paul as possible to save lugging them both around and changing guitars mid gig.
  • stevebrumstevebrum Frets: 4571
    That extra bit of info helps - maybe ask others if they’ve found one guitar (or modded an existing) to loosely cover the same ground as a Strat & Les Paul?
  • VoxmanVoxman Frets: 2280
    edited June 2018
    My PRS Cu24 is the most versatile of all my guitars and my all-round 'go to' because of it's ability to go from Les Paul-ish to Strat-ish tones.  Superb build quality and design, great trem system, excellent machine-heads with easy, fast string changing, great neck, and balances perfectly.  The PRS hard case is a bit big and overly heavy though but it doesn't feel 'right' to put it in another case so I live with that. I opted for the rotary p/up selector version instead of 3-way toggle plus push-pulls because the 5-way gives a great (for me) essential strat tone position that you can't get from the 3-way/push-pull.
  • xbrooomxbrooom Frets: 254
    edited June 2018
    ESP horizon?
    0reaction image LOL 1reaction image Wow! 1reaction image Wisdom · Share on Facebook Share on Twitter
  • baldybaldy Frets: 168
    "Lots to think about chaps, many thanks.
    I agree that the song defines the guitar and that Metallica on a 335 will sound like Metallica. But basically wanted something that sounds as close to my strats and les paul as possible to save lugging them both around and changing guitars mid gig."
    Exactly what i was looking for.
    I have a Yamaha 611 which has a coil tap SD bucker in the bridge & a SD P90 in the neck, very versatile guitar & under £400 used or around £550-£600 new.
    I also have a Yamaha RGX HSH which I have just swapped the pick ups on & fitted Entwhistle HB"s bridge & neck & a middle single coil.
    Again very versatile sounding guitar & again well under budget.
    Both will do stratty & LP sounds.
    I have a Yamaha Pacifica 611VFM too - and yes it's a lovely guitar and brilliant for versatility, and build quality is punching well above its weight. But I've got to create some space as I'm literally falling over stuff in my little den and I will have to let go of a few guitars and amps - because I have the Cu24 the 611 will sadly be on the list to go...once I can bring myself to make the painful choices.
  • DrCorneliusDrCornelius Frets: 1055
    There's a Musicman Luke II on here that ticks all of your boxes - decent price too.  (No affiliiation honestly)
    Leaning towards a PRS at the moment. Can't say I like the look of the Pacifica 611VFM - that big P90 up front just doesn't look right to me!
    I'm also prefer to buy a guitar from a shop where I can try lots of other guitars and find the one that is right. Personally would rather pay a bit more and do it like that. Really don't get how people buy guitars without playing them first.
    Cheers again all!
  • AlegreeAlegree Frets: 392
    I'm working on preparing a video for just this at the moment in collaboration with a big-ish guitar youtuber.
  • prowlaprowla Frets: 1325
    3reaction image LOL 0reaction image Wow! 0reaction image Wisdom · Share on Facebook Share on Twitter
  • SporkySporky Frets: 15050
    edited June 2018
    Teuffel Birdfish.
    Every year, I grow half as pretty, and twice as drunk.
  • SchnozzSchnozz Frets: 824
    *HSH Strat with Coil Splits - Jazz doesn't sound right with a Single sometimes.
    Cheers again all!
    If you don"t like the look of the Pacifica 611 there is the Pacifica 612 which is a HSS superstrat with wammy.
    Rock solid Yamaha build & versatile with the coil split Seymour Duncan HB, under £600 new or there is a used one on the classifieds for £325 iirc.
    You"ve probably guessed I am a Yamaha fan  =)
