Moog ep3?
John_PJohn_P Frets: 2750
Any long term users have any reviews on these?
Are a bargain or do they feel cheap and plasticky compared to a mission / EB / fractal expression pedal?
    I think quite a lot of people have them as they are relatively cheap. I prefer it to my Roland one, it doesn’t get heavy use but it does get used and I’ve had it a few years without problem.
    Probably ideally I’d have an expression pedal that offered a bit more resistance as it’s a bit easy to do big sweeps rather than something a bit more nuanced but that’s more of a problem with my heavy footedness and I don’t know to what extent the more expensive pedals would be better in that regard.
  • John_PJohn_P Frets: 2750
    Thanks for that.    Sounds like they worn ok - I’m pretty heavy footed as well so I like a big sweep - the mini exp pedal from hotone and amt are wasted on me.
     My main worry is that a few weeks of gigging and I’ll be ordering something more substantial to replace it and wishing I’d just spent the extra to start with.
    It is plastic, I’m sure it would be possible to break it but in normal use it hasn’t fallen apart with quite a lot of my 15stone bearing down on it.
  • BeexterBeexter Frets: 598
    I think they're great value and despite being plastic, they feel pretty solid. I might have one going up for sale shortly if you're interested. PM me for more info.
  • mburekengemburekenge Frets: 1058
    They're fine in use but as has been mentioned don't inspire a lot of confidence until you try them.
    the sweep on them are good enough, they do feel a bit cheap and feather light but they are robust enough.
    I'd personally stump up for a new TRS cable as well as the provided one is a bit flimsy
    Thanks chaps.  Appreciate the comments.    After a bit of thought I’m leaning towards a spring loaded mission but as they seem a bit thin on the ground I might try an ep3 in the meantime.
  • GavRichListGavRichList Frets: 7162
    Dunlop DVP3 is my favourite. Had the Moog and can’t argue for the money.... but you can tell it’s cheap.
