Back door man
quarkyquarky Frets: 2777
I live in a 2000 built house, and my wooden back door is looking pretty crappy. Is it easy enough to measure it, and buy a new one (from B&Q for example), or do I need to faff around with replacing the frame too? The frame looks OK at the moment to be honest..
  • IamnobodyIamnobody Frets: 6904
    edited June 2018
    If you are replacing with another wooden door of the same size you can just use the existing frame.
    Do you have decent locks on your existing door that you can transplant into the new door?
    Putting in those (or new ones) might be the hardest bit for a DIYer.
    Previously known as stevebrum
  • ronnybronnyb Frets: 1747
    UPVC. Relatively easy to fit, better insulation and more secure than a wooden one.
  • boogiemanboogieman Frets: 12361
    This. If it’s a standard size you can get them off the shelf from Wickes.
  • ZoolooterZoolooter Frets: 886
    I'm sure there's more than a few 'back door' men on here who are willing and very adept with a tin of creosote.
  • quarkyquarky Frets: 2777
    Thanks guys. I actually have an internal door where the mechanism broke (turn the handle and it doesn't open). I would feel relatively confident of doing that, but the external door worries me a bit more. Might go for the UPVC one as suggested and get it installed by a specialist :)
    Honestly it's not at all difficult. I never thought i could do things like that but i've fitted a fair few and never had a problem. As long as you measure the opening accurately and deduct about 5mm for the new frame to fit, the hardest thing will probably be getting the old wooden frame out. If you've got a hammer drill and a long masonry drill use 5 fixings (they're like long rawl plugs on either upright of the frame) into the brickwork and use expanding foam if there are any gaps. Don't forget to allow for the depth of a cill if there is one. Some of these window and door companies don't even use fixings, they just foam them in. When you look at some of the people the so called 'professionals' employ you'd probably do a better job yourself. (Apologies to any upvc fitters on here)
    edited June 2018
    If security is a priority then a good wooden door with a quality mortise lock beats UPVC, as does composite.
    Composite seems to the best choice between security and ongoing maintenance. They are coming down in price as well.
    The other disadvantage to UPVC is you lose door width.
  • 57Deluxe57Deluxe Frets: 7336
    yeah - why do they do that...??
    https://i.ytimg.com/vi/bvg9U_qG7Ko/hqdefault.jpg
    <Vintage BOSS Upgrades>
    Beware of those stupid thresholds the UPVC doors have. How you're supposed to get a flightcased AC30 in or out of one of those beats me. An extra 2" lip at the bottom? I don't think so! Demand a flat threshold.
  • fandangofandango Frets: 2204
    it stops them running away when you rip the shorts off  :o
    This ... although you should change the frame at the same time.
    Oh jesus. Screw that, then another wooden door it is :)
    Looks like the only gay in the village is stuck in the door
  • valevale Frets: 1052
    edited June 2018
    the UPVC ones are horrible. we had a nice wooden one & the council did a 'replace everyone's door, even though it's not broken' thing as part of an eco drive.
    the UPVC one wasn't as draughty in winter, which some might consider a plus, but a bit of through draught is not a bad thing if you have a coal fire. & it kept the house fresh (kids & cat smells). so we were not bothered about draughts.
    but on the downside, the UPVC one smelled of polystyrene for months, was far too light & swingy (so caught the wind & kept slamming, locking my mum out) & used to scare the cat in summer because it creaked & cracked all day under the sun's heat.
    wood is good.
    hofner hussie & hayman harpie. what she said...
    Wood is good but plastic is fantastic.
  • strtdvstrtdv Frets: 2438
    Composite is the way to go. Cost varies hugely by the type of door you go for. Our old front door was wood and we replaced it, along with the surround and an 18 inch pane of glass either side with a 70mm composite door with a large glass area in triple glazing, woodgrain foil inside and out and stained glass, along with matching stained glass triple glazing down each side. We also got a brass letterbox and knocker
    It was about £2400 but was a vast improvement on the old door and has a 15 year warranty and is virtually maintenance free.
    A 40mm composite back door with plain double glazing but foiled inside and out will set you back about £950 plus fitting
  • hywelghywelg Frets: 4303
    edited June 2018
    uPVC just says "I didn't have enough money to do a proper job".
    If you have a prewar house you will devalue your house if you fit a uPVC  front door. Composite door styles are rarely suitable unless you've modernised the hell out  of the whole house and you have no style
    If you live in an Edwardian or Victorian house do not fit stained glass into double glazed panels in the front door. Technically a bad idea but also the aesthetics will be hugely compromised.
