Sorry to be a pain, but I'm not a qualified engineer. I need some traction force questions worked out. I have two conveyor belts made by different manufacturers but to almost identical specifications. They describe the traction capacity of their respective belts differently which is confusing me as I work out that the belts should have fairly similar spec but haven't. Can someone tell me where I'm going wrong?
Both belts are 3mm thick 95shA polyurethane with no traction fabrics, just monolithic PU. I believe that 1kg = 9.8newtons.
Conveyor belt number one is described as having a traction capacity of 1.8kg/cm at 1% tension which I work out as;
= 1.8kg/cm
= 17.4N/cm
= 1.76N/mm
÷ 3 (3mm thick belt)
= 0.586N/mm2
= 5.86daN/cm2
Conveyor belt number two is described as having a 10daN/cm2 which I work out as;
= 10daN/cm2
= 100N/cm2
= 1N/mm2
Why would these not match or is one company over egging their figures?
Can someone put me out of my misery?
For those mildly curious, this is a monolithic conveyor belt;
What I do know is Kg (mass ) is not directly compatible to Newtons (force). I think there is a difference measure or unit for force Kg.
why are you doing this step?
Looks like kg/cm2 is almost 1:1 with daN/cm2. One step I think you did do wrong is there are 100mm2 to a cm2 not 10 but as you converted back to cm2 it doesn’t matter. Not sure if I’ve really helped there!
I can see how the capacity of the belt would vary with width, but the thickness of that belt is set at 3mm, no?
[edit] or should it be cm^2, for the surface area of the belt?
First belt's value is per cm whereas second is per square cm. You need the belt width of the first to be able to compare the two.
You'd expect the value to be a pressure ie a load per unit area rather than a udl.
Looking at the figures though, the second belt has a vastly superior traction force.
The belt looks about 30cm wide so belt 1 would be 0.6N/cm2 compared to 100N/cm2 for belt 2 and that can't possibly be right?
Is the lower figure within design capacity? Do both have matching frictional properties? Are they equal cost/CoO ? What is that cheese ?:)
