Hi all,
I have two DD3s in series, and wonder if there are any nice effects others use? I usually use them separately, one set to long, the other set to short, but sometimes I use them together, for example like this:
For nice chiming effect with a lilting beat:
1st pedal: level 80%, speed 1000ms, feedback 40%
2nd pedal: level 40%, speed 500ms, feedback 0%
As above but in 6/8:
2nd pedal: level 40%, speed 333ms, feedback 0%
For syncopated 3-over-2 beat:
1st pedal: level 60%, speed 500ms, feedback 30%
2nd pedal: level 60%, speed 750ms, feedback 30%
Anyone else using two pedals?
Roland said: Scales are primarily a tool for categorising knowledge, not a rule for what can or cannot be played.
Andy Othling does a great demo on delay settings for multiple pedals.
My music:- https://soundcloud.com/hubobulous
I think I’m more keen on the more ‘plucking’ sound than the ambient wash. I like the off-kilter repeats it gives you.
HIs Ambient #22 is a piece of music I come back to again and again
Interesting that it has to be the CC first, if it's second in the chain it effectively disappears with both pedals on. The effect I have is sort of wobble wobble wobble burp - it's not a smooth but more frequent set of repeats, there are definite peaks. If I have reverb on as well with either or both delays it smooths out the trails but in a band context that can be a bit indistinct and you are just playing a wall of mush.
I like the Billy Duffy dual delay thing ( 400 and 800 ms according to a quick Google) which is probably similar to the first example given by @viz although I don't have any obvious use for it.
