SOLD FS - Crowther Double Hotcake £150
Fully working, few teeny chips to the paintwork. The pedal sounds awesome as you'd expect and is really versatile, I'm just not using it with my current bands (and need the money!).
Here's some info from the website on how it works:
"The Double Hotcake has two Hotcakes: ‘A’ and ‘B’ in one box. The A is a Bluesberry version, and the B a normal version (the “Bluesberry” voicing of the Hotcake has a slightly less buzzy edge at the onset of distortion, and often works well when guitarists have amplifiers with extra extreme treble boost, like some Marshalls for instance). Both have three knobs and a footswitch as with regular Hotcakes. If both Hotcakes are switched on together, the A Hotcake drives the B, and its controls are bypassed, but an extra Drive control is switched in to adjust the its gain. There is also an extra clipping stage and a reduction in low frequencies to make for a better lead sound in the high gain situation. The A Hotcake has the usual buffered bypass (the circuit becomes a buffer in bypass mode), while the B Hotcake is hard bypassed using gold plated contacts."
£150 inc. P&P, I'll post some images later.
