Hypothetically thinking what I might do if I sell my Strat and looking at Jag's. I'd have a budget of UP TO £900 but would only spend what I perceive to be good value.
So, a bit of research hasn't really helped. I'd really want a nice dark, rich rosewood board so a new MiM is out as they are PF I think? Also Poly finish is a no no.
Have looked at some used MiJ / CiJ (?) used on Reverb (Gas Station Guitars) but apparently the Japanese stuff suffers from poor wiring and pickups, so you got to spend another few hundred quid to upgrade.
Please point me in the right direction!
The Mexican Classic Lacquer series is another good bet, as long as you're ok with skinny frets.
Anything else has slightly crappy pickups, though Jags are usually better than JMs.
Buy a Johnny Marr one.
In that order.
I think at 900 you are slightly pricing yourself out of what you want with your requirements. You might get lucky though.
I wouldn't be so quick to dismiss poly especially with how thick the nitro is on the Mexican stuff and the 62 avri stuff
I absolutely hate the feel of poly though. I could always strip it and get it sprayed I suppose.
http://www.thefretboard.co.uk/discussion/57632/
Yes, I've owned several.
Right! So does that mean they are superb and you keep buying more, or that you are still looking for a good one?
Yes. My mildly modified example fell under the gravitational influence of the Harry Seven warehouse. I think it now has the pickups from my AVRI '62 under the stock Japanese covers and screening claws.
http://urbanparanoia1.wixsite.com/harryseven/fullscreen-page/comp-irkm5hav/3ea6e6cc-3d9d-4fc0-8e21-f1fdb58eb7f0/106/?i=106&p=q17v5&s=style-ivmfprjj
I found the CIJ neck profile quite clubby and the nut width too narrow.
The vibrato system is inferior to the American version in several important respects.
+1 I upgraded everything on the master control plate.
Stupidly, Fender (Japan) applies that grey graphite screening paint to all of the cavities but does not link them to ground with yer actual insulated wire. Duh!
My local Fender dealership had a short run Jag that was proving difficult to shift. As soon as the guitar was offered at a discount, I snaffled it up. Two Seymour Duncan Antiquity pickups and some StayTrem parts later, it is a keeper.
The Ishibashi site - you have to order from Japan? What's the delivery time / charge like any import duties?
or you could hold out for a used (and hence rosewood) MIM classic 60s or roadworn 60s Jaguar. These are both nitro AFAIK.
Thinking about it, the change to PF is still fairly recent, maybe scan around a few of the less mainstream music shops, you might found someone still has a rosewood one somewhere.
The Classic Lacquer finish may not be super-thin like the thin skin of the AVRIs and the Johnny Marr, but mine has developed a nice soft patina which you don’t get with poly. The Roadworn Series have poly-finished necks - which is a moot point as most of it has been removed!
