am shopping for a decent but afforable case for a small semi-acoustic bass.
a violin bass in this instance but am actually not at all fussy about it being a designer violin-shape fit as i have a sewing machine so can make padding to fit anything.
so it could be anything you have tried that worked on a small semi-acoustic bass (30" shortscale).
i have looked at designated cases for violins (hofner & thomann beatbass) but i don't like shaped cases. they are annoying to have to think about packing so they don't get wedged among other cases. rectangluar play nice with all other rectuangluar cases (handles allowing) so that is my preference.
i have a standard stagg ABS guitar case & that has lasted me a decade & still going strong. am not flying off on world tours so it's just for backs of cars & vans. am not very muscles strong so ABS appeals. the wood ones seem heavy to me.
anyway, any ideas or recommendationa appreciated. thanks!
hofner hussie & hayman harpie. what she said...
https://www.gear4music.com/Guitar-and-Bass/Gator-GL-BASS-Rigid-EPS-Electric-Bass-Guitar-Case/MWN
It puzzles me why these aren’t more popular, since they have most of the advantages of both a hard case and a gig bag.
tbh i'm a bit nervous about that for the violin. the tallest bit is the violin-like sticky-out bridge + concave back (9cm or 10cm ish at quick glance). & it doesn't have a centre block, so true hollow body.
not sure that a semi-solid would survive dropping or something put on top.
am thinking maybe abs synth or keyboard case with required depth. it doesn't even have to be music oriented. just a solid rectangular case inside dimensions approx 116cm x 30cm x 10cm.
will maybe visit talkbass etc to see if anything suggested.
An actual violin is a lot more fragile - as well as a lot more valuable usually, even at the fairly low end - than a violin bass. OK, most classical musicians probably don’t put their cases in a van full of gear...
Yes, if you want a shaped hard case, then a Hiscox is the best. I have one, it's great. But if you want a case for any other purpose, or you specifically don't want a shaped case, then it isn't...
Also, try carrying a Hiscox on public transport along with something else that needs your other hand and you'll soon find that it's a massive pain that outweighs the extra protection it gives - that's why I use a Mono gig bag for that, with a £2K+ instrument.
I'm also fairly sure that Hiscox don't make a Violin Bass model.
Or under their chair in Pret-a-Manger, with a £1.2m Stradivarius inside... which then gets nicked.
The options are to have a Violin bass rattle around in their standard STD-EBS "F" sized bass case or to have it rattle around even more in their STD-EPB "large peardrop"
https://www.hiscoxcases.com/our-cases/bass-cases/
The solution is a rectangular case and an afternoon with a craft knife, cutting out foam padding to the outline of the violin bass.
i think i have come to the conclusion this is one of those blind spots that affordable generic off-the-peg cases don't really cover. so i'm basically out of the goldilocks case zone.
i looked at the bass equivalent to my trusty stagg ABS (damn good guitar cases for £50 actually) and it seems to be too shallow (8cm). which figures as it's made for solids (sounds gross). i need 10cm min (sounds even more gross).
normal semi-acoustic & acoustic bass cases are going to be mega huge & so it would be rattling around in there like a pea in a skip. violins are only a small headstock longer than a regular 6 string guitar & actually thinner bodied than most widthwise. & def a pita on public transport.
i know someone who works in a second hand music shop so maybe i will leave dimensions with them & wait to hear if they anything affordable comes in. & keep an eye on gumbay obvs etc.
thanks all.
Shame you aren’t close to me - you could try the Ibanez semi hollow I have which is a piezo bridge job - it’s a proper good bass and is 90% of that violin bass sound but far more everyday-useable. I love the sound in an acoustic setup - it’s been through one of those posh AER amps and it sounded really rich and thumpy.
One of these
https://www.andertons.co.uk/ibanez-srh500-def-electric-bass-in-dragon-eye-burst-flat-srh500-def?LGWCODE=SRH500DEF;56375;6335&gclid=CjwKCAjw9-HZBRAwEiwAGw0QcX0O9pvIQXABzQMVEMCUHpLFxnX2IApVCIgVnY7sS9SzD8e0K3PkrBoCWh8QAvD_BwE
Honestly - impeccable build, glorious acoustic tone and really really playable with a nice slim neck and 24 frets..
