contactemea@fender.com
Instagram
I'm just making an assumption but there were reports of the flash coat being fragile in some instances, and I suspect reverting to the poly sealer speeds up production and reduces costs as well as being more durable
As far as the finish goes its still very early days, but this thing is 100% going to relic with time... Maybe not quite like the early 60's and 50's guitars but much more like the late 60's and early 70's guitars which I have read from multiple sources that they did use a sealer called Fullerplast which is a type of polyester.
Compared to my poly finished guitars it does have different characteristics, sweat hazes up a lot quicker, its a lot softer and easier to scratch.
As for sinking into the wood grain I guess that is something only time will tell as that won't happen over night. But if i'm going to guess it probably won't, I think this was something more common with the pre fullerplast Fenders.
But don't let the finish put you off, just play it a lot and leave it out on a stand so it can catch some sunlight and I sure it will age nicely over the years.
As mentioned already, older fenders weren't totally nitro. The colour coat was acrylic. In fact some custom colours had no nitro lacquer at all. That's why some white strats are still white, not yellowed.
