Put this kit together over the weekend. It's probably the most complicated kit I've done, but it's still just a case of following instructions and getting decent solder joints, right?
Anyway, it's working fine apart from a bad hissing sound when activated, seems to be affected by the gain control and the treble. It does it when the guitar's volume is at zero.
The problem I have is that, since I've never played another power boost or clone, I have no idea whether it's just a noisy circuit, or whether the tones I'm getting from it are right. With strat single coils, this kit is a beefy clean boost all the way to the end of the gain control where it gets buzzy, fuzzy and compressed.
Schematic can be found in the
build doc, but I'm not sure how to diagnose a potential cause of the hiss from looking at that. Can anyone help me out?
It's less noisy running it off the cioks dc5 (I was using a onespot yesterday, not a daisy chain but just a single 9v mains adaptor) but it was picking up very clear radio.
I often find circuits are much noisier when I am testing them as opposed to when they are properly boxed up
This picture is (I think) before I fixed the backwards bass pot ( ) and tidied the CLR connection (I always forget not to put that on the main board ( )
I've my best to keep it neat but I didn't want all straight lines and right angles (which I'm aware can lead to noise issues)
What will probably happen is - since I've got a taste of the power boost and liked it - I'll probably try to pick up a fancier version made by someone who knows better about building stuff that doesn't pick up noise and radio signals.
I said maybe.....
In spite of the radio noise, it actually sounds really really great. It seems a sophisticated circuit (and a refined sound) compared to other boosters/fuzzes from the late 60s.
In that case, it sounds very like PSU/switching noise from the charge pump, and nothing I do cures it.
* I've built loads with no issues, no aspersions on Fuzzdog in general.
If so, chances are you have a fake 7660S. There's a lot of them about. Even the TC1044s from Tayda squeal. Best to get your 7660s from Rapid or the like. They're considerably more expensive, but you do at least get what you're paying for.
I said maybe.....
I said maybe.....
One question about the shielded wire idea - I'm guessing you mean the grey stuff you see in D*A*M pedals and stuff? How does the shielding work with those? Does it get grounded at one end?
You can get charge pumps to be quiet, however you need to pay care to the layout; for example you should a separate ground for the charge pump and for the audio. These need to be connected together at one point only and you may need chokes to reduce noise.
You also benefit from extra filtering on the power rails, especially if you are using single ended gain stages that don't benefit from the power supply noise rejection properties from op-amps.
Furthermore, as stated above, there are plenty of fake charge pump ICs out there. The most reliable and robust I've come across is the Linear Tech 1054, but make sure you get this from a reputable supplier.
Trying to sort out any power supply filtering / layout issues retrospectively is hard, to say the least.
