FS - Roland GR55 Synthesiser - with GK3 pickup and Hard Case - PICS ADDED
Hi all,
I have a black Roland GR55 synthesiser, with the GK3 pick up. It is mint condition, exclusively used at home (and seen very little use) and has an aftermarket hard case (and its original box).
The only thing I have used from it is one of the plastic strips to stick the pickup in place, but there are loads more in the box. Also I will include an aftermarket stainless steel bracket which allows a semi-permanent (but easily reversible) installation to almost any standard stratocaster (it uses the screw holes from the pickguard so leaves no permanent changes to the guitar).
I picked this up just before my first child was born and as a result haven't had any time to get to grips with it, it's had less than 3 hours use.
https://i.imgur.com/fix8T7v.jpghttps://i.imgur.com/39Gy6aq.jpghttps://i.imgur.com/TanWUa1.jpghttps://i.imgur.com/cON0lzp.jpghttps://i.imgur.com/HJNQwOe.jpghttps://i.imgur.com/SUQeW6R.jpgI'm looking for £390, but would consider partial trades for a THR10, El Capistan or a Cali76 Compact Deluxe.
I'd prefer collection (I'm based in Taunton but could travel south to Exeter or north to Bristol to meet) but I would post at buyers expense.
Thanks,
