Why can I often not get any suds when washing my car? I use the car shampoo as directed but the foam never happens (even if I put two or three times the amount of stuff in it still doesn't get soapy) and all I ever get is a whispy bit of white stuff floating on the surface of the water in the bucket. Washing the car is then really frustrating and I end up using most of the bucket before I've finished half the car.
I've tried different buckets, sponges, car shampoos etc but nothing seems to make a difference.
And then about every one in ten washes I do exactly what I've done before and, low and behold, more suds than a Tom & Jerry cartoon.
I know hard water can be a factor but where I live the water quality is very good.
Just wondered if there's a definitive scientific reason.
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
I have a stash of Power maxed car shampoo sachets, that were being given out at various motor sport events I've been to, that stuff's brilliant.
Nope, I get lots of foam while the water is running but it quickly fizzles to nothing when the incoming water is turned off. Just don't get it.
Even that doesn't work bud, much the same as above.
I use a cheap Tesco shampoo and it bubbles loads, but also dries horrible. I used to use autoglym stuff which was nicer, but now I drive an Aygo and it's not really a car that screams out for detailing
Because generally they use washing up liquid that strips the top coat, a pressure washer at full blast to damage any bearings it can find and the same dirty sponge full of grit off 30 cars to scratch your paint work?
No, water quality here is very good.
Tips:
Shampoo into bucket, warm water from tap
Once near full, add a little bit of extra shampoo then stick your power washer into the water and spray until you get mega, mega suds.
Nice one for trying to get this right as the less friction there is, the better
Interestingly the Autoglym blurb for their Shampoo (not their Shampoo Conditioner) says "Rich foam quickly breaks down and removes everyday contaminants". As a result I'm led to believe the foam doesn't hang around, but if it disappears really quickly, it suggests there might be an issue with water quality. Or you're being stingy with the shampoo.
I have to admit the two capfuls instruction is a bit pointless if there's no cap to fill, and there's a flip lid instead, so I'm fairly liberal with adding the shampoo to the bucket of water.
* a different (better?) product than their 'Car Shampoo'.
Also in this weather (you probs know already) dont wash it if the cars hot. The paints softer and easier to scratch, but also the shampoo and water will dry leaving water stains!
I found megs stuff gave me a better lather than cheaper brands, but its not really an issue. How slippery it is is more important.
Something like a mammoth wool mitt will help over a (God forbid it) a sponge...
Proper snow foam with its own lance will really coat the car in suds, but its a pre wash treatment, to loosen off hard debris before the contact wash to help minimise scratching.
Unless your detailing a detarred, deironed and clayed car thats been polished and waxed or sealed, I probably would bother with the hassle of it!
Water hardness will affect the amount of duds but shouldn’t kill them altogether. Something is breaking the surface tension of the surfactants, my guess would be grease or oils.
Try a new bucket and sponge
If you leave a saucer of water out in the kitchen you get limescale on the windows..
Done all that, no real difference except as I said every one in ten washes will foam up lovely. Very weird.
I've tried loads of different shampoos from Autoglym to Turtlewax and everything in between. I've just bought a new one, Demon something or other - will see if that works soon but I'm not holding my breath.
