Helix Advice - Use with Fender valve amp and could it switch them and reverb on the amp?
jimkehoejimkehoe Frets: 208
I am super impressed and happy with my Helix but am contemplating getting a small Fender valve amp as well such as a Princeton or Deluxe.
Obviously I would only use the effects on the Helix straight into the front of the amp as Fender amps rarely have effect loops.
Would I still be able to utilise the effects and sound decent through the amp?
Secondly is there any way of using the Helix to switch the amp's reverb and tremolo on and off?
Normally a Fender amp has a two button footswitch with a TRS/Stereo type plug which plugs into the rear of the amp.
Thanks in anticipation for the incredible advice, knowledge and opinions which undoubtedly will now flourish !
  • John_AJohn_A Frets: 3775
    Yes, and Yes
    Helix sounds great as FX only and you would just need a TRS (stereo) cable to run from the Helix to the amp for channel switching.
  • WazmeisterWazmeister Frets: 9514
    Yes and Yes !
  • exocetexocet Frets: 1958
    John_A said:
    Yes, and Yes
    Is this the case? I know that the Fender HRD is not standard TRS switching (it's voltage differential of something like that). I know that you can make a HRD work with a Fractal FX8 by making a special cable that has diodes (forward and reverse). I guess that the same approach would work with Helix.
    Just done a bit of googling and you are right it's not just a straight forward latching footswitch.  You may have o do some investigation/tinkering to get it to work
  • ICBMICBM Frets: 72245
    The Princeton and Deluxe Reverbs do both use standard latching footswitches. Old ones use a dual RCA jack arrangement, reissues use a TRS jack.
  • jimkehoejimkehoe Frets: 208
    Thanks to all for the encouraging and useful advice.
    So if I have understood correctly: if I get hold of a 65 Princeton or a 65 Deluxe Reverb re -issue I will be able to connect the Helix to the amp's  footswitch input via a TRS cable and assign one of the footswitches on the Helix to switch the amp's reverb in and off and another footswitch on the Helix to switch the tremolo on and off?
    I know nothing about the Helix end of it :). But if it has two switchable amp-control jacks then it should be.
