PSA: Axe-Edit 3.0.8 Released
Handsome_ChrisHandsome_Chris Frets: 4779
edited April 2014 in Amps
Fractal Audio Systems - Axe-Edit 3.0 Software Editor for the Fractal Audio Axe-Fx II Guitar Processor
NEW FEATURES
1. Modifiers can be directly accessed from the Controllers:Modifiers page by clicking on the details of a specific modifier.
ISSUES ADDRESSED
  1. Corrected preset conversion from Axe-Fx II to Axe-Fx II XL. Note: Because of the different number of User Cabs on each model, you will need to manually reselect a desired User Cab by its name or number after preset conversion.
  2. Corrected an issue where individual presets within an Axe-Fx II bank would not be imported into the Axe-Fx II XL via the Import Preset menu.
  3. Corrected the Picker window’s scrollable view area to correctly show only the vertical scrollbar instead of both vertical and horizontal scrollbars.
  4. Corrected the issue where Axe-Edit was not updating correctly while running Cab-Lab or after exiting Axe-Manage.
  5. Corrected an issue where Axe-Edit was not updating the block parameters correctly after linking a Global Block that
    was saved in one X/Y state to a block that was in the opposite X/Y state.
