Doh!
Still, it was on a Jaguar so it will still fit a Strat or something else... and I did have another packet of the same strings to hand, so it was easy to replace.
Nicked one out of another set, picked the guitar up to play it, and there was thunk as the Fishman battery dropped off the inside of the heel. Bloody heat has done for all the sticky on the velcro pad, so tonight I'm going to have to slacken it all right off and put some more aggressive sticky stuff on it. FML etc.
Example on my Larrivee:
https://i.imgur.com/PSslENK.jpg
The original installer did it right up in the shoulder of the guitar, which made the battery pouch a swine to get at. The pad (not pouch) fell of there after about 18 months after being left on a stand throughout summer, so I stuffed it back on the base of the neck, although it's not ideal because there's not a lot of wood there (big hole for a bolt (not truss rod) access) so you can only glue the border. Have just put it back with a bit more "enthusiasm" and won't be storing the guitar vertically in the heat.
Shame, because I quite like the pre-amp (Fishman Matrix Blend) but I can't be doing with this shennanigans every couple of years.
