Bought this off Reverb the other week with a view to completing a tele build 2 years in the making. Decided to just save up and buy something I like.
Info from Musikraft:
It was a roasted neck with a clear gloss finish and total cost was close to $700
Here are the specs:
ORIENTATION: Right for Right Handed Players
HEAD SHAPE: Standard Vintage Tele
SCALE LENGTH: 25.5 Standard Fender
NUMBER OF FRETS: 21 Fret
NUT WIDTH: 1.650
HEEL WIDTH: 2-3/16 Standard Fender
TUNER HOLE SIZE: 11/32 Vintage Kluson
TRUSS ROD TYPE: Single Acting Adjust at the Heel
FB RADIUS: Compound 7-1/4 to 9-1/2 + $25
NUT SLOT STYLE: 1/8 Standard Fender Flat Bottom
SHAFT WOOD: Rock Maple
TOP DOTS: Black Plastic
CUSTOM INLAY: None
SIDE DOTS: Black 2mm
12TH DOT SPACING: Wide (Vintage Pre 64)
FRET WIRE SIZE: EVO Gold 6230 Vintage Small + $50
FB EDGES: Heavy Rolled Non Bound Only + $40
BINDING: None
BACK PROFILE: Chunky U 90 99
FINISH: As Selected from the Finish Menu
MOUNTING HOLES: Drill Holes Standard Fender Pattern
NUT INSTALLATION: Install Slotted Bone Nut + $75
The neck is in superb condition with only some slight chips around the screw holes on the back with will not be viable when attached to the body.
https://imgur.com/gallery/jYn2XLO
£300 including postage
NOW £250 and it’s gone on eBay
please
