SOLD: Laney HCM30B practice/beginner bass amp (moved)
SnagsSnags Frets: 5369
edited September 2018 in Amps £
In good condition - all works, a bit crackly on some pots and some dust/splash marks on the sides but nothing that shouldn't clean out if you wanted it shiny. It's basically sat under a table in the lounge for years without ever being used. Mrs Snags is of the opinion that this is sub-optimal.
Active/Passive inputs
Bass, mid, treble
Gain
Volume
Compressor switch
CD/line inputs
DI, external cab and headphone outputs
£25.
Based in Hertfordshire, and fairly often in some parts of Oxfordshire. Not really a postable job. Could also bring to the Huddersfield jam if that helps.
Pics coming when I can get the links working
EDIT: moved to Amps£ because I am a tit and wasn't thinking straight last night
