Both amps sound better turned up but as they are 40 watts this can be challenging unless you're gigging.
http://www.thefretboard.co.uk/discussion/116794/divided-by-13-jrt-9-15-head-choice-of-2-heads-purple-or-cream#latest
The 9 watt setting with 6V6s is great for home but it can be wound up and hold it's own at gig levels. Same with the 15 watts of EL84s. Great pedal platform, too.
It depends what you want. For cleans and a great pedal platform, I'd choose a Hotrod Deluxe IV. The volume taper is a bit better so it's more manageable at home, but it's still 'effing' loud.
Thanks - Very useful. The map any would replace would be a 65 reissue Princeton which is great but just thought the V40 deluxe would give a bit more variance. Also when I tried the trem and reverb they both sounded great.
Good luck with your search
