Second of all, it looks like he's imposed a preset on the track, so you could click on the button at the top of the mixer channel where it says "Warm Vocal" and select something like "No preset" or "No plugin" (can't tell you off the top of my head).
Or make a new Audio track and move the region to it .
That said, for an over-the-top solution: if you make a new audio track, put the play head at the start of the current region, go to the Project Audio window (Windows, I think > Open Project Audio...), find the audio you want to use, then there's a menu item for Add to Tracks, and it will insert that audio onto the selected track at the current playing position.
... and is it worth getting into this at all if you're not going to do anything insane? I think not ...
... saving the current version as an Alternate. Then, as Lindsay and Tobias would say "you have it".
Normally, in Logic Pro, MIDI and audio are mutually exclusive. They cannot exist in the same Track.
For example, in Apple Loops, some of the loops are n bars of audio. If you drag one into a Project, it has to be into an audio track. Other loops are MIDI. When those are dragged into a Project, Logic creates the Instrument that will replay the sequenced note data.
From the pictures you provided both are audio, it is just one is green and one is blue. You can change colours by going to 'View/Show Colors'.
As to what has happened on that track, it will be very difficult to troubleshoot remotely, because it could be many different things.
If you want to make a video showing all of the drop down windows and tool selections then I can troubleshoot it.
Otherwise, create a new session and import the audio/midi data.
I would select Cmd A and then copy/paste between two open sessions.
This will be quicker than trying to troubleshoot the session weirdness.
If you need to create track/channel strip presets then do so.
https://support.apple.com/kb/PH12936?locale=en_GB
https://ask.audio/articles/understanding-audiotomidi-in-logic-pro-x
This created a new midi track though, for me at least.
