Chord Of The Week 24/8/13: Open Position Power Chords
bigjonbigjon Frets: 680
edited August 2013 in Technique
Open-position power-chords across several strings:
C5: x3x013
A5: x02255
G5: 3x0033
E5: 022400
D5: xx0235
B5: x24402 (play 5th string with your thumb)
What are your favourite multi-string open-position power-chords?
  • vizviz Frets: 10691
    edited August 2013
    The A one's my fave. You are wise and have been recognised appropriately.
  • mike_lmike_l Frets: 5700
    edited August 2013
    I believe Kossoff used that A5 in All Right Now......
    Not technically an open position but I like
    079900
    for a held E5, not so much for quick changes/strumming (I like it less for strummy parts)
    I also like the 022400 E5
    And the G5. As used in Motorheads Ace of spades
    *edit*
    Why is this in the Guitars section?
  • Lexie1Lexie1 Frets: 135
    I do tend to use this a lot for G  355033 I really like what the open G String does for this, works well in the F position as well.
    Whoops, you meant in the Open Position. D'oh.:(
    In that case, I use this quite a bit for D  2X032X or 2X0320 when I want a slightly different voicing.
  • FezFez Frets: 522
    Plus 1 for the A5
    I concur it should be in Technique.
    Don't touch that dial.
  • bigjonbigjon Frets: 680
    Moved now
    079900
    for a held E5
    Your 355033 for a G5 from last week's Gmajor discussion was another goodie
    How do you play that?
    edited August 2013
    Thumb the low E string.
    1st finger  on high e & B strings
    3rd finger on A & D strings
    Nicked from Rainbow's Since you've been gone
    Next time you see me, I'll show you
    I'd do 3rd finger on the A string, 4th finger on the D string instead
    Also that voicing of G5, can be moved up to the 5th fret for a variation on the A7 (no 3rd)chord
  • close2uclose2u Frets: 997
    I didn't see the AC/DC classic
    e 3
    B 3
    G 0
    D 0
    A x
    E 3
    Bigjons first post....
    my bad - need to read more carefully
    079900
    It's used as a strummy chord in "Ordinary World", which I played at the Earl of Derby jam last week. Also isn't there an early-ish moody Metallica song with an E5 - D - C - B progression where that shape is strummed for the E5 and moved down the fretboard 2 frets at a time for the D and C chords?
  • SporkySporky Frets: 28148
    It's not really a power chord but I really like x02200. Is that an A9 or sommat?
    A5add9 but often played as an Asus2 leading into an implied or actual A x02220. I'll do another CotW sometime on open 5add9 chords - there are loads of good ones.
    edited August 2013
    That could be any number of early Metallica songs. The one that's springing to mind is "Welcome Home (Sanitarium)" which is (Clean) B5 C5 D5 with a low E and a D drone.
    Master of Puppets (Intro) is E5 (12th fret) D5 C#5 C5, then low E /B/Bb/A/Ab/G/F# riff.
    Both off the MOP album.
    Leper Messiah off MOP has a silimlar descending power chord section (and inverted power chord section)
    Feel free to ping me any other questons on these albums
    That's the one. Moody interlude about 3 & 1/2 minutes in. 8:41 onwards in this link
    edited August 2013
    I can't see the link at work, but (IIRC) the clean moody part is Em, Bm7, C, D, but it has been a while. I'll have a check later
    corrected, see below
    edited August 2013
    To correct myself the part you're referring to is
    Em D Csus A(sus2) B D#5 (Played arpeggiated)
    CHords
    Em 0 2 2 0 x x
    D x x 0 2 3 0-2-0(Hammer/pull on high e)
    Cadd9 x320x3x (The E note is only played at the end of the bar)
    Asus x0x20x
    B x2x20x
    D# xx120x
    with a low G to turn back to the Em
    Same part is played later with distorted guitars
    Hope this helps Bigjon
