Bass Design
JezWyndJezWynd Frets: 6058
I see a lot of basses these days sporting an upper horn that's attached to the neck, such as this example from ACG -
What's the thinking behind the design? Increased resonance, sustain?
  • My guess is rigidity.
    The shorter the amount of unsupported neck, the more rigid it can be.
    More rigid necks lose less energy when notes are played. Most noticeable with thick low tuned strings eg a low B
    Personally I’ve found a preference for rigid bass necks, it’s also possible to achieve a more rigid neck with reinforcement rods or multi laminate construction.
    I haven’t played one of these designs but I’d guess it also balances differently on a strap.
  • ICBMICBM Frets: 72297
    It's designed to prevent degenerate forms of expression like rock 'n' roll.
    Makes it look like a whale.
    Once you see it, you can’t unsee it...
    It does have some other similarities... like producing non-repeating meandering melodies which go on for hours and which no-one has any idea of the meaning of.
    There’s a smugglers hideout in the back of it for us bass players to keep the crochet/Jazz standards/pencil and sharpener etc
  • FunkfingersFunkfingers Frets: 14422
    Would Dee Dee Ramone have used one?
  • JezWyndJezWynd Frets: 6058
    That makes sense, esp if you're using a B string. Presumably the payoff is increased sustain. There must be more attractive ways of solving the problem though. Maybe dual truss rods?  ;)
    They do hint at 'earnest musician'. Oh for the good old days when a serious expression would do the job.
    :) Yes, or a shorter neck.
    http://cdn.shopify.com/s/files/1/0195/7232/products/IMG_4774.JPG?v=1444113057
    (Originally designed to be tuned E-C I know - but I don't see any reason you can't do B-G.)
    I always worry about the balance on strap with those big humped single cut designs...
    15 frets! I suppose the fifth string could be to counter that limitation. Good for dub maybe?
  • UnclePsychosisUnclePsychosis Frets: 12886
    edited August 2018
    Eliminate the neck/body join altogether. ;)
    http://www.stick.com/instruments/sb8/
    I never play higher than the 15th anyway - and even that only on the lower strings - so it wouldn't be a limitation.
    The original intention of the high C string was to make it easier for bass players to play shapes across the neck instead of runs up higher, as you probably guessed.
    It is certainly the only 5-string I would want to play, anyway...
  • valevale Frets: 1052
    so lazy bass players like me, who play thumb-over style instead of jazz-spaz spider style, will never be reduced to even touching such a hambone monstrosity. we will remain pure and untainted.
    hofner hussie & hayman harpie. what she said...
