I've recorded with one of these at a studio a few times and I always feel theyre phenomenal amps. Best guitar tone I've ever had has been recording with these (their outboard gear helps too).
I was thinking of buying one, however, the guys in the studio said that theirs is relatively unreliable and doesnt 'travel well' which isnt ideal for gigging (predominantly when I'll be using it).
Anyone have any opinions on matchless amps (independence in particular) and how reliable they are? Everything I've read online say theyre built like tanks as its all point to point hand wired etc.
Cue a **Anyone had a BadCat blow up??** post in a fortnight....
(formerly miserneil)
Great, great amp.
I had it for sale for a bit but couldn't part with it.
Fantastic clean channel and the drive channels really cut through live.
It takes pedals very well indeed.
It was a head but I bought a matchless 112 combo shell with speaker and swapped it into that.
The only thing that failed has been the power valves, to be fair I was running it through an attenuator a lot, and the reverb tank.
It certainly benefits from nice valves, you can tell the difference more in that amp than any other I have.
Here's the insides
http://i63.tinypic.com/2s15aba.jpg
Second question. Boy this thing is loud! I'm not really sure how Impedances etc work, would I get the same volume using a 16ohm cab as a 4 ohm cab as long as the impedances are matched? I know I heard something about using a different can work in you getting less output (I can remember if it was going into a lower ohm or higher ohm cab) but I know if you do it the wrong way it kind of breaks everything.
As the Independence has 4, 8 and 16 ohms on the back I was wondering if say using a 16 ohm cab would get me less overall output than a 4 ohm for example?!
Apologies if this is a stupid question, I have literally no idea about these kinds of things, just going of of something I'm probably remembering wrong from reading somewhere!
Later I compared a Matchless Lightning 15W combo to a Marshall TSL60, which is actually a valve amp (although the weakest '60W' one I've ever heard) and again the Matchless was louder, although not by as much. But that's still a four-fold power difference...
Yes.
No, this is not a good idea. Firstly if you mismatch too far - more than up or down by one 'step' really - there's a risk of damaging the amp (or with a Matchless, more likely just the valves), and secondly it won't even affect the volume that much.
With a solid-state amp, it can be done - it's safe as long as the cab impedance is higher than the amp, and reasonably effective.
Whilst matchless don't recommend attenuators, I sometimes used mine with a Hotplate without issue. And I found following their JJ valve recommendation to be the best option for me through my rigs, so didn't feel the need to invest in overpriced NOS valves
Seriously, a great amp
yeah no worries, i dont really get 'electrical' stuff, so wasnt sure if i'd get a higher output from a particular ohmage or what. Tbh, I'll probably give it a go through my small victory 1x12 to see if that is a more manageable haha.
Awesome sounding amp though! So glad I ended up with it.
I see what you did there .
Clever, but no...
It's usually much less critical than popular wisdom will have you believe. There are a few exceptions, but generally any valve amp will take a half to double impedance mismatch with no trouble at all, and often 4:1 is OK. It's also always OK if the amp isn't cranked.
But it's still not a good idea to use a severe mismatch (eg amp at 4 ohms, 16-ohm cab) to try to reduce the volume of an overdriven amp, that *can* cause damage.
Sorry to be dull, too good an opportunity to miss .
