So, I have a Morningstar MC6 MIDI controller and I’m using it to change patches on my DD500. However, I’m stuck with how to select the higher banks/patches, since there are only 127 MIDI channels and 297 patches on the DD500.
Currently I’m sending a PC message to the DD500 for patch changes but according to the DD500 manual, I need to send a CC message to change banks. But, it only shows two numbers - #0 and #32. I’m confused by this, what does it mean I need to program into the MC6?
http://i86.photobucket.com/albums/k100/keir_smith/9697B678-A447-4EFF-B168-C7CBA7F85F06.jpg
I’m presuming I need to select which bank I need with a CC message, and then specific patch within the bank with a PC message - is this right?
If so, I’ve tried what I thought would work and it doesn’t, so I’m guessing I’ve mucked up the programming somewhere.
Here’s what I’ve got:
http://i86.photobucket.com/albums/k100/keir_smith/CFB94744-E3A4-4EEF-BA4D-CD53ECE0EB40.jpg
And I want patch 99C
http://i86.photobucket.com/albums/k100/keir_smith/8C48205E-3F53-45C1-B76E-8817708974B5.jpg
So how do I do this??
I recall it's done via pc numbers in groups of 3.
Pc1 = patch 1a
Pc2 = patch 1b
Pc3 = patch 1c
Pc4 = patch 2a
Etc
Ebay mark7777_1
I *think* that LSB needs to be off and then MSB 0 = bank 1, MSB 1 = Bank 2 and MSB 2 = Bank 3
So to get bank 99c, you need to send MSB 2, PC 041 (which is shown as bank 3 - PC 041 in the midi map)
The Boss manual is so unbelievably shit.
Would I need to put CC message as 0:99, and then PC message as 3?
Will also have a look at this later tonight
Goto 2 mins 30
Of course I dont know if the morningstar sends MSB data
I must be doing something wrong as I can’t get the Boss to change patch at all with a CC messages 0 or 32.
on the GR55 it's send CC 000 then a value for the bank
(with user banks being (value) 0, 1, 2 and then 16, 17, or 18 for the factory banks,)
then send cc 032 with a value of 000
then send a program change for the preset in the bank selected.
so as an example to select preset 2 in factory bank 1
my controller can send on multiple channels independently and I have each device listening on their own channels so I also have to prefix each command with a MIDI channel number so I actually send
As others have said the DD500 manual is not exactly user friendly but it seems to indicate that the DD500 works in a similar manner albeit with the bank numbers being different.
manual
cc 00 with a value of 01 (or 02 or 00 for the different banks)
then cc 20 with a value of 00
then a PC for the patch (try 00 through to 09 first)
if that works then try sending patch numbers 0A, 0B etc.
cc 00 with a value of 001 (or 002 or 000 for the different banks) (looks like you only need to enter 0, 1, or 2)
then cc 32 with a value of 000
https://www.youtube.com/watch?v=gtEeyAKu1A8
