This evenings gig was progressing very well when inbetween songs I wanted to check my tuning. Kick on the Polytune (v1 normal size) and it all lights up lovely then after about 5 seconds displays "BATT" alternating between tuning and "BATT". Hmm I thought. I checked all the cables were connected properly and started the next song.
A bit later I wanted to tune again, kicked on the pedal adn this time lights flash up nicely but "BATT" comes up and then it turns off and I can't use it for tuning. Kicking it on repeats - shows "BATT" and turns off.
Weird I thought, I don't remember putting a battery in there.
I get home, take it apart, and there is no battery in there at all (quite right as it's powered from a voodoo labs power supply on my board.) I check out the manual and it says "Low battery indication - When the battery runs low on power the display occasionally indicates this by
writing “BATT”." - but I HAVE NO BATTERY IN THERE AND ITS MAINS POWERED. If there was no mains power it would light up and display "BATT". But there's no battery in there so why's it showing "BATT" indicating low battery?
All my other pedals were operating fine.
What is happening? Is my pedal on strike, has it got a disease, will it ever work again?!
Anyone else had this ?
