Apparently cold drip is a bit different too
Instagram
https://home.lamarzoccousa.com/brew-ratios-around-world/
It’s a different extraction to espresso because it relies on time rather than pressure and heat. It will always be lighter, sweeter and fruitier. You need a higher quality bean to make the most of it.
Instagram
Either that was all bollocks, or this new fangled cold coffee has a whiff of wankochino about it..
Then on a separate glass, you have a bit of condensed milk and bunch of ice cubes.
then you mix everything.
Instagram
Could I just brew it with hot water like normal & then chill it in the fridge afterwards? To reduce the 12 hour time.
its really no bother if doing it overnight, but it will take a few attempts to get something you are happy with
Instagram
It takes a lot of ground to get the same tasting strength, like twice as much. But you get similar amount of caffeine.
http://www.cafedumonde.com/coffee
Thanks @Wez will g@ ;
Ordered a tin from Sainsbury’s to try out:
https://www.sainsburys.co.uk/shop/ProductDisplay?storeId=10151&productId=1248210&urlRequestType=Base&catalogId=10123&langId=44
https://alternativebrewing.com.au/immersion-cold-brew-drip-cold-brew-coffee-right/
Instagram
My tin of coffee didnt turn up in the end...out of stock
its a nice way to make a cold drink during summer when I fancy it and immersed a batch when the family came to stay in Spain this summer.
but could not see it becoming my normal daily drink on a cold January morning.
I have a reusable cup, and that gets me a filter coffee form Pret for 49p ! That'll do fine thanks !
