However, you can use it in "momentary" mode (only engaged whilst the switch is held down) but there's not a toggle AFAICR, you just hold the switch down for longer.
Try just giving it a quick stab, rather than keeping your foot on it?
That's how it's supposed to operate. If it doesn't then you probably have a faulty pedal.
Before the drive (or in the front of the amp) will give you more drive (more gain/breakup).
In the loop (after drive/pre-amp) will give you a volume boost without changing the gain (unless you're hammering the power valves already ).
Great little pedals.
