Kahler USA G4200 Style Hybrid Trem & Locking Nut For Les Paul (mint)
catdogcatdog Frets: 124
edited August 2018 in Parts £
From what I know these are very rare & very sought after ...Trem system for Les Paul guitars comes with the locking nut too if you decide to fit it & its all in mint condition but missing studs... Offers ££££ ?
  • catdogcatdog Frets: 124
  • WezVWezV Frets: 16668
    edited August 2018
    These do need a route under the existing bridge.   Also, a behind the nut string lock works better than using it as a locking nut, unless you build up a shelf for it to sit on (the Floyd style nut can be used either way)
    I really like kahler’s, one of my favourite trend for dive bombing.... totally different feel to a Floyd .  but they are not a drop in replacement for any guitar.
    edit:
    the route
    https://www.whammyparts.com/faq/68-kahler-frequently-asked-questions/184-kahler-routing
    Worth pointing out you have the locking grub screw on the back edge too, then trem can be locked in place really quickly
  • FunkfingersFunkfingers Frets: 14424
    catdog said:
    No body routing
    Interesting. Where does the cam go during upwards bends?
    Also, where are the Kahler mounting studs, the support "wheels" that replace the threaded studs for the Tune-O-Matic bridge and their respective threaded inserts?
    Sorry if my questions appear negative or mean. The questions need asking because the vibrato that you are offering is incomplete. Hoarders such as @HarrySeven and I may have the relevant spare parts. Most normal human beings probably would not.
    IMO, the string clamp in the OP photographs does not comply to any known Kahler design. It is a licensed FR item.
    There are some other parts here.  I will upload  pics shortly. Thanks for the heads up.  I don’t know much about these at all as it was a trade so any help would be greatly appreciated
    edited August 2018
    This being a newer model (post 2008) means spare parts are still available easily, including the risers for $10
    https://www.whammyparts.com/kahler-replacement-parts/4200-stud-mount-x-trem
    This version is still available new at $359 + postage and customs charges... which should be minimal for the risers, but you would get stung on the trem unit
    https://www.kahlerusa.com/stud-mount-tremolos-bridges-6-string
    actually that'slightly different again
    its this one @$289
    https://www.kahlerusa.com/guitar-tremolo-and-bridge/7200-6string-stud-mount-hybrid
    I am goin by what I read on the net.  If I’m wrong about the body routing I will sort it out in the listing
    These are the installation instructions
    https://www.kahlerusa.com/public/pdf/5790RIMA.PDF
    any of the above part of the trem ?  that's all that was in the box
    edited August 2018
    Ok so im open to offers on this or if someone has spare studs & inserts they wanna part with ?
    edited August 2018
    the 2 thumbwheels are the important risers for the kahler
    The plate and 4 screws are a vibramate (v7 style i think) sell that separately as its nothing to do with the kahler.  Its used for fitting a bigsby to a carved top guitar, but you are missing a plate that goes at the strap buttom end
    http://www.vibramate.com/vibramate-v7-lp-install.php
    Wez is correct on all counts.
    IMO, the Vibramate parts deserve a listing to themselves. Plenty of Bigsby fans on tFB. Should sell quickly.
    thanks guys   so is it just the studs missing from the kahler then ?
    In theory, the Kahler should fit on the stock Gibson tailpiece studs. Sometimes, things do not sit nicely. Also, the exact colour of the electroplated finishes might not match. This could bug some people.
