I have been Googling and found conflicting information on this, so I thought I'd ask and see if anyone had one and could check..
Basically, I want to know if the switching modes (A <-> B or A <-> Bypass etc) switch just the
sends or whether they also switch the
returns. In other words, are the returns
always mixed into the output?
What I'm trying to achieve is the ability to put pedals that generate sound without continual input (ie loopers, delays) into one of the loops, and then be able to play over them, but still have their output mixed into the resulting signal.
I guess this could be most easily tested by putting the pedal in A <-> B mode, plug a guitar directly into return A, plug the output into an amp, and then see if stomping on the pedal makes any difference.
I know I could achieve this with multiple pedals (eg an LS-2 plus a killswitch or a A/B box) but I wanted to know if I can do it with the LS-2 alone.
Hope that makes some kind of sense.. thanks
I no longer have one to actually check for you. I don't actually know why I've still got the tatty piece of paper for it.
(Edit - doh! Took out something unnecessary.)
Will that do what's needed?
Which makes the LS-2 a very handy clean mega-boost, but I digress.
And yes, that means you can use it as a two-stage clean boost - although you have to cycle round off > A > B > off etc.
