the northwest guitars stuff is decent, in fact they sent me a tele body by mistake when I ordered a strat body from them. It looked really nice I thought... sent it back for the correct body tho’.
they are finished In poly but they are good.
the strat body I have ended up with is really good!...
Lots of things. Type of materials, and the quality of those materials, quality of machining, quality of fit and finish etc.
Now, many inexpensive instruments look fine and work perfectly well in their own right. But many do not actually conform to Fender specifications, so you might find you have to keep the bridge or the neck as nothing else will fit - not helpful if you want to use them as a source of parts.
By way of example I purchased a new Fender Mexican Classic Strat body from First Avenue Guitars at the start of the year, around £150. It's two piece alder and beautifully machined and finished, and as it's Fender, then Fender spec parts fit without hassle. A similarly priced complete guitar would probably be 4, 5 or more pieces of indeterminate wood prepared as a spread, maybe veneered to hide the joins, or maybe just finished in thick poly. And fit and finish would be nowhere near as good as the Fender body.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
I’ve modded a HB tele and built a partscaster from the best parts I could afford. I’d start with the best body and neck I could afford in future.
They’re the foundation of the guitar you WANT- if you’re going to upgrade the hardware it seems daft not to invest in the bit that you hold, touch and look at.
Plus some budget models have slightly different dimensions meaning that your “posh” parts might not fit easily.
The only advantage of upgrading a cheapo is that you have a guitar you can play from the start.
The scratchplate, bridge and control plate screws would go in but never really bit, they’d turn forever and never be what I’d call tight.
I’m guessing it was fixable by filling all the holes with stuff, but I reckon it was cheap body woods that caused the threads to strip at low torques.
When I built my strat, I bought a body from guitarbuild.co.uk and finished it with a kit from Wudtone. If I was doing it again, I'd probably buy something from SC Relics which is a bit more expensive, but cool.
