JAM BIG CHILL TREMOLO:
“One monster of a flexible Tremolo !”
GUITAR PLAYER magazine
“While the vintage tone hits the spot, versatility is the key word here”
GUITARIST magazine
The Big Chill is a flagship tremolo pedal with a slew of functions that will take you from lush smooth tremolo sounds found in vintage Fender amps, to strobe-like chop effects capable of slicing through any mix!
· Square – Sine – Triangle waveform selector toggle-switch
· 4 control knobs for Level, Depth, Speed 1, Speed 2
· Foot-switch to select between Speed 1 / Speed 2
· Foot-switch for the CHOP effect ! (the DEPTH control is not working when the CHOP effect is engaged. This is perfectly normal – just give a quick listen to the CHOP effect inaction and you’ll understand why !)
· Expression pedal input jack to control Speed 2*
· Expression pedal input jack to control depth (the Depth control on the pedal sets the maximum depth for the travel of the expression pedal)*
· Internal trimmer to adjust the Speed 2 level
· Internal trimmer to adjust the CHOP effect level
· The Big Chill can also be used as a clean boost! Just set the Depth control to zero, and adjust the Level to your preference.
All these features along with the warmest and biggest vintage tremolo sound you have ever heard ! We are extremely proud of our creation !
The BiG CHiLL can also be used with bass guitars.
Technical information:
· True-Bypass
· Controls : Level , Depth, Speed 1, Speed 2, Square/Sine/Triangle toggle switch, CHOP fx footswitch
· Internal trimmer to adjust the level of the CHOP effect.
· Internal trimmer to adjust Speed 2 Level.
· Works with a 9V battery or 9V boss-type DC adaptor (tip-negative)
· Uses 15mA of power when ON
· Dimensions : 120 x 94 x 30 mm
· Weight : 0,35 kg / 0,8 lb
From GUITARIST MAG REVIEW:
You can choose from three tremolo waveforms - sine, triangle and square - and have the option of two speeds, selectable by a second footswitch.
"The classy range of sounds, including vintage Fender, should suit most players' tremolo need"
Each speed is set with its own knob, while there's an internal control to set the second speed quieter or louder than the first.
There's also a knob for tremolo depth and one for the output volume that offers a useful boost (set the trem depth to zero for boost only); you can also use external expression pedals to control tremolo depth and the second tremolo speed.
A third footswitch brings in the CHOP effect, a more brutal square wave on/off tremolo that chops the audio into segments.
The classy range of sounds, including vintage Fender, should suit most players' tremolo needs, but it's the switching and control that set this apart from other pedals. While the vintage tone hits the spot, versatility is the key word here.
Would cost £230 new. Yours for £120 PPG shipped within UK. No original box but will be properly packed.
T REX MOLLER 2:
Identified on That Pedal Show as one of the closest sounding and most credible alternative to the King of Tone pedal. The T-Rex Moller2 Drive has a combination of drive and clean boost tones that makes a great foundation for a great pedal setup. Step on the left button for the drive tone and when you reach that blinding solo the right button boosts you through the mix.
Here's what T-Rex have to say about this pedal:
Møller 2 delivers the same classic overdrive that made it's predecessor one of T-Rex’s most sought-after pedals. Named after Danish guitarist Knud Møller, for whom the original pedal was designed, Møller 2 features a more durable “Bass Boost” toggle switch and easier-to-read control knob graphics. The pedal is armed with a 0-20 db Clean Boost, as well as a Mix control which lets you dial in the perfect balance between distorted and clean signals. Rolled all the way up and with distortion maxed, the pedal sounds just like a vintage tube amp at full volume. Roll the Mix knob back a bit, and your clean signal starts to get through; if you pick lightly or roll back your guitar volume, you get a stunning clean, softly-clipping sound that retains all the feel and dynamics of your original tone, only bigger, louder and richer. The boost function lets you dial in a solo level, whether the overdrive circuit is activated or not.
Specifications
· Power: 9v DC
· Battery option
· Connectors: Input Jack, Output Jack, 9v DC Jack
· Size: 100x55x120mm
· Weight: 345g
£90 PPG delivered within the UK.
JAM BIG CHILL STILL AVAILABLE.
