Trading feedback | FS: Nothing right now
JM build | Pedalboard plans
https://www.musicstore.de/en_GB/GBP/Wishbone-Workshop-The-Amp-Hook/art-GIT0043653-000?campaign=GShopping/UK&gclid=EAIaIQobChMIi4mi_ZiD3QIVDr7tCh3qkAf1EAQYAiABEgK65_D_BwE
I have some clip on mic stands that came with ym superlux e609 rip offs and I used those for a bit but in the end I found getting the gooseneck right where you wanted it was a bit of a PITA so ended up jsut using a mini-mic stand of the sort you would use for a bass drum.
At some point would def like to get one of the bracket style ones though.
Cheaper than those spring loaded clamps and much more precise.
Once youve installed the little bracket, you get precise close Mic placement time after time.
https://goo.gl/images/mWSDHu
<○> Big Norm Feedback
https://www.thomann.de/gb/audix_cab_grabber.htm
I could do it for £30 posted
FWIW the 609 & 906 are supercardoid which also means a bass boost when placed close to source. For that reason you might even prefer it off the grille cloth rather than hung/placed against it.
https://thumbs.worthpoint.com/zoom/images1/360/0712/30/proel-el700-speaker-amp-stand-km10_360_fce89e66313d243d5a441f338ecb4b1a.jpg
I didnt have any problems buying mine, in fact it came in less than a week too.
Result
So I went back to a compact floor stand, and got a much more stable position.
