Most other acoustic amps are just a little too small to do a decent job for both at the same time in my experience - although the old Trace Elliot TA100 is OK.
I've got an Acus One at the moment, but I haven't tried if for both at once
A powered PA cab or FRFR monitor would also work as Bridgehouse said, but it's likely to be a bit bigger and heavier, and you will need an outboard preamp for the guitar unless it's got a very comprehensive onboard system.
