I'm building a strat FINISHED! (well, not quite ...)
axisusaxisus Frets: 28285
edited October 2018 in Making & Modding
Guitar no 4 has problems, so I'm putting it aside for now to get on with Guitar no 5 - A strat.
So without further ado - some pix:
Gluing body wood together
Neck thickness sorted
Truss rod channel routed
  • axisusaxisus Frets: 28285
    Neck shape done
    Ageing metal with acid fumes.
    Machinehead holes sorted
    Wood too thick for my bandsaw so a bit of pre-cut work.
    Then trimmed
    Routing body shape
  • DrBobDrBob Frets: 3003
    Yep, deffo looking like a Strat John, coming along really well!
    Yup - looking good! :)
    Cutting fret slots and drilling marker holes
    Top (and rear) routing done as well as neck pocket. Outer shape also sorted
    Roundover sorted. Dirt cheap router bit but I got away with it!
    Shaping contours.
    Body mostly sorted and sanded bar a few tweaks. I have to say that I am very pleased with how it has gone. Most satisfying.
  • That's coming along very nicely, @axisus ; :)
    Because they are such a familiar shape, you tend to forget just how relatively complex they are...
    Respect!
  • paulnb57paulnb57 Frets: 3053
    Nice work!
  • jaymenonjaymenon Frets: 814
    edited September 2018
    Just beautiful - and its amazing that you are actually making the body and neck from scratch (for me building a start means buying a free parts and putting it together like an Airfoil model).
    May I respectfully suggest that you contour the neck block / rear of the lower horn like the Guthrie Govan Charvel? Makes upper fret access so much easier...
  • duotoneduotone Frets: 982
    Great job, its looking brilliant.
    Bookmarked for future updates!
    Made some imitation clay dots, baked in the oven
    Truss rod sealed in and strip planed flat
    Fretboard attached and edge trimmed.
    planning placement of trem screw holes.
    Mock up of guitar so far.
    plastic and metal parts aged a bit. Doesn't show that well in this pic.
  • Excellent :)
  • LuttiSLuttiS Frets: 2243
    That looks amazing - good work :)
  • OilCityPickupsOilCityPickups Frets: 10264
    Looks brilliant!
  • WOW!! looking excellent so far, absolutely love it!
    making a template for the trem screw holes.
    Drilling holes.  The template has double sided tape on then was clamped with pressure to make sure it stayed put
    fret markers fitted, slots cut deeper to allow for fretboard radius
    Radiusing fretboard.
    9.5" radius sorted. I might take it down a bit more tomorrow though.
    Latest progress
    Sanding neck shape
    Pressing frets in and trimming
    Smoothing fret ends. Basic fretting done
    Making a template for drilling the ferrule holes.
    aligning tuners to drill fitting holes.
