I had one for a few years and gigged it in jazz bands and a covers band. I probably didn't appreciate it for what it was at the time but I had to move it on due to the weight (one night traipsing across Edinburgh with the Classic 30 in one hand and a hard-cased pedal train junior in the other nearly killed me!). The clean channel was big and bright but I rarely had it pushed past 3, the reverb was good and the overdrive channel had a lot of colour to it. I always felt that not making the boost function foot switchable was a bit design flaw though. All in all, they are a super solid combo amp that can cover a lot of ground.
Edit. On the Peavey website, the Boost now looks to be footswitchable. The version I had wasn't.
Also good - they are loud, and relatively light. Also bad - they run very hot, can rattle, and eat valves.
The Fender Hotrod/Blues Deluxe is a much better-made amp, but larger and heavier. Its clean sound is better - easily one of the best at this price point - although (not in my opinion, but popularly believed) the overdrive isn't as good. The Blues Deluxe has a slightly more vintage-sounding clean channel and much less gain on the drive channel (and no second drive mode) so if you want that just-breaking-up sound I would get that.
I meant to add that a sleeper in the Peavey line is the Delta Blues amp. They come in 1x15 and 2x10 variants and are pretty excellent amps.
I've ranted about the C30 build loads of times over the years, so I won't do that again.
What I will do is point out that a Hot Rod Deluxe will have lower long term running costs even if it costs a bit more up front.
When I sold my HRD, the power valves had probably been in there for 5 years. When I had a C30, I had to replace them every year because they got really rattly - to the point where you could hear it through the amp. The C30 also uses 4 power valves not two. 6L6s valves cost more to buy than EL84s, but given that you only need 2 valves, not 4, and that they will last a lot longer, the HRD will be much cheaper to run long term. If anything goes wrong with it, it will be cheaper to fix as well.
I don't know what the speaker is like in the newer HRDs (probably not great), but the older ones with the Eminence speaker definitely sounded better with a speaker upgrade. I had a Weber 12F150 in mine, and it sounded really good - up there with a lot of the expensive "boutique" amps.
