Cleaning a tweed amp?
lincolnbluelincolnblue Frets: 294
Out of interest, is there an easy/safe way to clean a tweed amp covering?
  • WindmillGuitarsWindmillGuitars Frets: 731
    I used carpet cleaner to good effect on a Tweed Deluxe once.
    Warning - you will remove mojo.
    www.windmillguitars.com - Official stockist of Yamaha, Maybach, Fano Guitars, Kithara Guitars, Eastman Guitars, Trent Guitars, Orange Amps, Blackstar Amplification & More! (The artist formerly known as Anchorboy)
  • Modulus_AmpsModulus_Amps Frets: 2574
    Depends on if the tweed has been treated with shellac/lacquer or not.
    if not then you will probably struggle to get any stains out of the cloth and possibly leave marks behind, I think most new Fenders do not have shellac/lacquer applied.
    if yes you might win with some warm water first, maybe try some soap after that and then a scrubbing brush.... i.e. ease into it.
    Or burn it with some cigarettes and tow it behind the car around the block and you will have a road worn version.
  • GassageGassage Frets: 30887
    Turn the volume down below 6 and it’ll be a lot cleaner.
    7reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • springheadspringhead Frets: 1590
    Or below 2 for a Deluxe to get clean!
    Is it grubby beyond a desirable state of natural relicing? Given that people do try and age tweed amps to make them look old and knackered/loved.
  • 57Deluxe57Deluxe Frets: 7333
    edited August 2018
    I got a big discount on my 59 Bassman cos it had a black 'boot scuff' on the side panel. The dealer had not been able to get it out. I used Dettol Mold Remover  and it sorted it well good.
    http://www.express-cleaning-supplies.co.uk/custom/upload/images/products/resized/1000x1000/1252987.jpg
    <Vintage BOSS Upgrades>
  • Thanks all. I had been asking as I was looking at a few tweed amps, some with quite a few marks on them. I've ended up going for a different amp so won't need the cleaner. Thanks for the tips though
  • KitsuneKitsune Frets: 292
    Tweed is too full of moral fibre to be cleaned.
  • DrJazzTapDrJazzTap Frets: 2168
    I used to use vodka. If you have some mould or blackening on the tweed, the vodka will kill the spores off. Then use a damp cloth with some water to wipe off the vodka. Then leave the amp in the sun to dry off.
    /\ White Vinegar is better at this and cheaper!
  • JerkMoansJerkMoans Frets: 8792
    ...but doesn’t give your amp the bouquet of having done three world tours with The Pogues...
    Inactivist Lefty Lawyer
    /\ you need to piss and vomit on it then!
    Oh ok: Gogol Bordello, then :D
  • NPPNPP Frets: 236
    dry cleaning perhaps?
