I've had a Zoom G3x for a couple of years now, bought it to run alongside my THR10c for home use. Playing the Zoom through the Aux of the 10c, I still marginally prefer the THR tone for clean to mid gain stuff.
I usually set the G3 up with a boost or TS, amp on clean or break up and then with reverb and the Air patch. I might add a delay, tremelo or chorus but generally thats it.
I've been gassing for a Helix LT but i'm not sure if that's total overkill, and wondered if I'd be put off by just constantly messing about with editing patches rather than playing.
I like the fact that the zoom has a looper, although it could do with being longer, and with a save option. I like the fact the zoom comes with simple rhythms rather than just a metronome. I also find it fairly easy to dial a sound in now that I've got the factory presets turned down from what they were on my custom patches. It also accepts audio into the unit via USB so its easy to jam along to stuff by connecting a laptop or even a phone.
What I dont like about the zoom is the need to scroll through the footswitches in the patch (only 3 windows), and I think that the amp sims and overall tone could be better (as the THR demonstrates)
I play through headphones and will be buying FRFR/monitors if continuing down this route. I'm strictly a home player but do like good tone to inspire me.
I think the new Zooms seem to be a bit of a retrograde step, so looking at the other options out there and was curious as to where others have gone along a similar path.
I've just decided to go for a Vox Adio Air, although thats an all in one. Ideally I'd get an amp modelling pedal unit which I can use alternatively with looper etc.
Cost £350 new last year and it's going nowhere, I love it.
I use it in 4cm plus MIDI with a 100w Katana head. The on screen PC editor (Tone Studio) is dead easy to use and there's a world of adjustment with everything. It's a really useable and flexible unit that's built like a tank and big enough to not feel cramped. The switches are all good quality and nothing has ever let me down.
Honestly it's one of the best pieces of gear I've ever bought.
Was always intrigued by the EZ TONE feature. I thought it looked very useful.
Do you bother using it?
Using Tone Studio on the PC is so easy it's almost redundant to me.
It will operate with two signal chains that split and then mix back together or leave it split and output in stereo, there are more amps and effects than I could ever wish for and they all sound great playing live.
I can't comment on recording because I know FA about that and I've never used it that way.
I've heard the odd few negative things about COSM modelling and this *is* the previous "Gen" compared with what's out there now so I'm not saying it will compete in all areas with a Helix.
As always factory preset patches aren't great but they can be if you tweak them to suit your guitar and amp. I found it was the EQ on each patch that's not set very well but then what would Boss set it to so that it sounds good on every guitar and amp?
It needs some time putting in to sound good and Helix is no different in that respect.
I've never seen it as "Option Paralysis" I simply see it as "Lots of options without spending thousands on pedals" but I can set up a simple patch in just a few minutes so it's only as complicated as you want to make it.
If your priority is ultra quick and easy, buy pedals and don't go for this or anything like it.
If you've got time and some small amount of patience and you want something with a Toys R Us style UI (User Interface) that sounds like a really great board full of pedals 90% of the time and is a joy to operate, use and store away then something like this is ideal.
Similarly, if you want to get most of the experience of Helix but you can't stretch to one in terms of money or it's your first go at a big multi fx and you're not sure about dropping a huge amount of money on one, I'd say this is ideal.
Real world restrictions are:
No XLR outs. (Use a DI box.)
Only 1 FX loop which is taken up by using it in 4 cable mode. (Put pedals before or after the GT or its FX loop depending on what they are, as you would with any normal pedal board.)
It's big. I personally love that, others don't.
That's it really.
For the money, especially used, they're a bargain and a massive step up from the Zoom platform.
I buy patches from a place called Boss Tone Garage for a very reasonable price. The guy emails them and I load that file straight into the GT.
It's not good at being a MIDI controller to any other MIDI controlled devices you might have. So, when you change patches, your flexibility to send the right MIDI commands to other devices is limited. That's not a concern for me.
The twin screen system works very well and you can programme the unit without needing to have a computer attached if you want to. The Boss Tone Studio software is good, though.
I agree with @Alnico that this is a great starting MFX unit if you want to find out if you want to be in the MFX game and it might turn out to be all you actually need (even if it's not all you want).
£10 for 18 presets sounds decent value & then you have the time that week to use/learn them.
I'm not ruling out buying another multi fx,I've bought the Adio to A/B against my THR10c and decide which to keep. Its the option I can go to if I just want to plug in, hit a preset and get the most out of practice time. The G3x currently bridges the gap when I want a bit more, to use the looper and to use the stomps and multi fx with either backing tracks or music played in through the USB. Its this area that I'd like to improve on tone and to get something without digital fizz (although I do think I have dialled a lot of it out of the Zoom with adjustments). I'm also just starting to use recording tools so to have so many tones and options at my fingertips is inspiring.
Im planning on visiting some of the bigger music stores over the next month to try out these in person and make a decision but i'll certainly digest what you've provided and see if it ticks all of my boxes. The boss option is certainly on my list now.
No problem man, just thought it's worth typing it all out since I'd already started and try to answer most FAQ's before they happen.
I've just got a Zoom Q2n recorder so I might try to put together a video on the GT100.
It could serve me as a vehicle for learning video editing as well.
I doubt this will be a quick thing but it's worth me trying to do.
To be continued. ...
