My guitar is buzzing at the 3rd fret and I can see that there is zero relief in the neck so I am trying to loosen the rod. It's an epiphone - truss rod is accessed at the head end - allen key type nut.
I am sure that the rod has never been adjusted and the guitar is 35 years old. I bought it off a chap that had it cased in his cupboard practically all its life. Still had the cellophane on the pickguard and original strings when I got it!
Since a restring with 10s the buzzing is less so, but the truss still needs a quarter turn.
What would you advise?
Should I put the allen key in and give it a light tap to free up and build up of "stuff" over the years?
Should I use some lubricate - I have some singer machine oil?
Should I clamp the neck straight and then then try adjusting?
Any tips/help/experience appreciated ...
dont force it with the Allen key alone.
also try a small turn in the opposite direction first, but that’s normally the solution when they won’t tighten
Instagram
It's not really bad and the guitar plays great even with the slight issue at the 3rd. Intonation is spot on too.
I did try tightening but it was not budging either..
Cheers
