Hopefully by the time I'm done with it the uke will be just as picturesque... Maybe.
It gave me a lot of idle time in the hospital...
My original idea was a scaled down version of this:
http://www.kennysmusic.com/wp-content/uploads/2018/06/martin-ceo-7.jpg
But f-holes and an arch top are a classic look so how about a scaled down version of this?:
https://i.pinimg.com/originals/e4/ae/8b/e4ae8beb7169e475e875841a09cba18e.jpg
I've ordered a new plank for the top so I can decide later. It's flat and not thick enough to carve so we'll see how that goes.
Do you think Stradivarius or Guarneri sound holes would be better for the delicate tones of the ukulele? Or perhaps something more alternative...
I really like the re-top for F-holes idea.
Instagram
Instagram
https://i.imgur.com/lo7sceb.png
Erm...
New idea, The Cwtch Guitar Company.
CGC
Cwtch:
a cupboard or cubbyhole. a cuddle or hug.
Perfect - a sound box is like a cubby hole and a hug is what I'll need when I muck things up.Is the Cottage in the image above a holiday let? It looks our kind of place.....
I had googled 'beautiful Welsh barn' and picked it out. Apparently it is a holiday rental on a working farm in Snowdonia.
So far I've spent more time translating Welsh words than I spent looking for the kit.
https://i.imgur.com/HAqNCkJ.jpg
Lovely view out of the window this morning... What do you mean 'it's a painting'??
https://i.imgur.com/h2YkRC2.jpg
https://i.imgur.com/Pyyoo8o.jpg
Preparing for son no2 meant it got a bit repurposed during redecorating a kitchen and a two bedrooms.
While I wait for a break in the weather let's have a look at the kit.
Body looks pretty good. All laminate but I didn't expect anything else (and will match the new top).
https://i.imgur.com/zgUIg8R.jpg
https://i.imgur.com/qDQQHPw.jpg
https://i.imgur.com/z6aMxGT.jpg
https://i.imgur.com/5cUMfds.jpg
Neck is made up of a fair few parts!
Headstock seems a bit off to me...
https://i.imgur.com/vtUtCnp.jpg
https://i.imgur.com/MACyEEf.jpg
https://i.imgur.com/dMjb2mS.jpg
https://i.imgur.com/rTdMdXS.jpg
Fretboard is actually really nicely figured.
https://i.imgur.com/k5oD31N.jpg
https://i.imgur.com/Xhrh7mb.jpg
But doesn't fit the neck that well so will need some neck reshaping.
https://i.imgur.com/lqJbbi9.jpg
Nut and bridge look fine.
https://i.imgur.com/reSW6xa.jpg
https://i.imgur.com/wOPL8iy.jpg
Tuners aren't bad either, I might have a go at aging the buttons.
https://i.imgur.com/KFTmidT.jpg
Finally drew an outline on the top - I want to try and make a forming tool and bend the top then add braces to hold the shape. This could go terribly wrong!
https://i.imgur.com/VMYwESk.jpg
I'll be doing a dark dye near the top so it should hide the dark spots if I get to use this piece.
Hopefully tomorrow I can do a couple of tip runs to empty the workshop.
Reminds me of the hand positions in Picaso’s guitarist picture:
https://en.m.wikipedia.org/wiki/File:Old_guitarist_chicago.jpg
Due to the small scale of Cwtch Co and the fact the owner and managing director spent most of the last 3 weeks Cwtching the client for this build I decided to outsource the logo creation to a well renowned marketing company.
They have proposed the following logos for market research ... So which one do you like?
A.
https://i.imgur.com/BGpR126.jpg
Or
B.
https://i.imgur.com/AFQa29f.jpg
On to the important bits!
For a Cwtch instrument this headstock was way too pointy.
https://i.imgur.com/EElQPZu.jpg
https://i.imgur.com/u411VCl.jpg
That's better!
I wanted to create an arch top and had some idea that you could form ply so I've had a go with some ideas that seemed like they would work and... It sort of did.
First step was to get the ply soaking in warm water to make it more malleable - I was going to do this for longer but the 'wet chamber' started leaking and threatened to cause water damage to the 'grounds maintenance building'.
https://i.imgur.com/EPLKbXp.jpg
While the top was soaking I made up my bending jig.
https://i.imgur.com/lhTT1lY.jpg
https://i.imgur.com/YVg4Wac.jpg
Clamping it up slowly trying to keep even pressure...
https://i.imgur.com/LhzbgBP.jpg
Once tight it was on to the 'acoustic drying kiln'
https://i.imgur.com/7HRv2ut.jpg
It was looking great but started to show the squareness of my jig underneath so after a few hours I bottled it and took it out of the jig. Here's the underside showing where I should have put a radius on the 'bending bar'.
https://i.imgur.com/jxanNQm.jpg
The top is not massively domed but it has worked in both directions!
https://i.imgur.com/BfJbKNr.jpg
Now I need to work out if I need to brace it and how the f$%^ I'm going to cut it out and cut the sound holes (any suggestions welcome).
no idea about bracing, shouldn't be much more difficult than the cutting bit.
