I've been playing for way long enough and should know this already, but I've always had vintage, single channel style amps with no loop and never had a problem putting my pedal in front.
But recently for that sake of practically I jumped on a cheapo Vox AV30 (and I really like it). It's the first amp I've ever had with an effects loop and was wondering if I should be using it.
The effects I use are Delay (MXR Carbon Copy), Tremolo (JOYO), Wah Wah (Crybaby) and I need to add a boost for solo's/single note melodies etc. (any suggestions).
I understand the basics that the loop sits between the pre-amp and power amp sections of the amp but was wondering what should I be putting in the loop and what should be going in front.
Cheers
I've got a couple of pedals I could use as a boost for that volume lift, a Cali76 Compressor or ZVEX Super Hardon.
I tried the compressor last night going straight in, it gave me a bigger sound but not necessarily a volume lift. I'm guessing its because I already have the pre-amp driving quite hard, so there's no more headroom to offer a volume boost. Would I have any success dropping either in the loop instead?
Alternatively I could just use the second channel on the amp. Use identical settings on both channels but set the volume a little higher and get a footswitch.
In theory a plain boost could do the same but you’d need to be adding such a huge amount of volume that I doubt it would be usable anyway, and I’ve never come across it being a problem.
Generally a wah will also sound bad in the loop, but won’t cause any harm.
Everything else is just a matter of experimenting and seeing what sounds good to you.
(You can run an external preamp etc into the FX return to bypass the amp’s preamp, as long as it doesn’t come from the send.)
Plenty of players sounded alright before loops were invented so don't get too hung up about it.
I have played around a bit using 4cm (4 cable method) but found it was just more trouble than it was worth. For what I do and how I sound and how much effort I'm willing to put in. So YMMV.
Adam
(FX that go in front of the amp)
Cable 2 - pedalboard/multi-FX send point > amp guitar input
(Amp's preamp)
Cable 3 - amp's FX send > pedalboard/multi-FX insert return
(FX that go in the amp's FX loop)
Cable 4 - pedalboard/multi-FX main output > amp's FX return
Adam
Assuming you're using the amp gain for overdriven sounds I'd be tempted to try the boost as the final pedal in the loop to give you a volume boost for solos. Generally, by running it into the front of the amp you'll just drive the pre-amp harder, resulting in more gain, but not much, if any, increase in volume. It depends how much gain you have on the amp though.
With the pedals you mention, personally I'd go with:
Guitar > Wah > Amp Input
Amp Effects Send > Tremolo > Delay > Boost > Amp Effects Return
As already mentioned though, you may prefer the sound of the tremolo and/or the delay in front, so always worth experimenting.
