Hi Guys... I've just noticed that if I lightly brush my fingers along the lower half of the pickguard on my brand new, 1 week old, Fender Telecaster, moving from the front, running back towards the control panel, I hear crackling/interference coming out of the amp. Is this caused by poor insulation along the route of the cables running from the neck pickup to the control panel, and if so, should I take the guitar back to the shop? I had to wait 3 weeks for it to arrive, so I'm hoping that I don't need to return it... the crackling is loud enough to be annoying so I'm sure something's not right...
Cheers, Hansi
TO DO IS TO BE - Nietzsche TO BE IS TO DO - Kant DO BE DO BE DO - Sinatra
To cure it permanently you might need to put shielding foil on the back of the guard, making sure to let it contact the control plate - a small piece stuck to the body under both works well. That will drain away the charge.
Sounds like static noise to me. You could put some shielding on the back of the guard where you're caressing it - you could probably make an ok connection to earth by just leaving a bit sticking out under the control plate.
No more static.
Si
Regardless, mine also had mental static on the pickguard, which if you rest your 2nd 3rd and 4th fingers on it while picking, like you said is enough to really colour the sound through the amp.
Hope that its an easy quick fix for ya. Its a common enough problem.
Be sure to let us know the results man.
IIRC the chap that was once here who worked for Fender said that roughing up the back of the scratchplate (sandpaper) should get rid of the problem, as it helps "disconnect" the plate from the body.
