I have a 8.2k Bridge Humbucker with an Alnico III magnet in LP that I'm considering tweaking
It's currently very bright on the unwound strings with only just enough definition on the wound strings
I'm not yet done with trying to vary the height of the pup, but assuming that doesn't get me there, I'm considering a magnet swap to either an Al II or a IV - Not a fan of Alnico V in HBs and I play on the edge of clean and so exclude ceramics by default
So here's the question
If I want to tame the top end a tad but not loose wound string definition, should I go to Al II (which will tame the top, but might make the bottom end more muddy) or go IV (which risks brightening the top end more, but might allow the bottom end to come up to a level that balances that out)?
Whaddya think?
If UOA3 doesn't work, you'll want to ditch the pickup.
It is hard to give advice like this though. Humbuckers are by their nature softer on the low end. What you might prefer is something like a Firebird or mini HB bridge pup so the string sensing area is smaller and roll the tone pot off slightly to smooth the highs.
I have a set of Antiquities in a Tokai 335 semi and although they sound great they are a bit flat in the mids.
They don't sound scooped but they just lack a little mid push especially the bridge. I can live with the neck pickup because I mainly play on the bridge.
Are you still happy with the swap?
What am I like!?
Just a normal, down to earth, guitar playing guy with a serious touch of gas......quite normal, no remedy required.
Thanks for the reply, I might just try a set of PAF 36'ths I have in another guitar because they have slightly more mids. Saves magnet swapping!
