Not sure if this pic will help (camera on my phone is a bit knacked)...
Input wire (red) goes to bottom left, jumper across to top right, output wire (yellow) from middle right.
Input wire to board (green) goes from middle left, output from board (yellow) goes to bottom right.
Top left to top centre jumpered.
Board ground (black) goes to middle centre with a ground going to the output jack sleeve.
Bottom centre (black goes to LED ground.
http://i426.photobucket.com/albums/pp345/ewal_01/1397076550077.jpg
cheers dazz
good luck.
dazz
Double check your input and output wiring. What happens if you remove the in/outs to the board from the switch- do you get any signal pass through at all?
I recently built the sho clone and its bloody brill!
