I'm repairing a cheapo Squier for a friend and one of the coil wires is broken off from the solder points. I can't multimeter the pickup because of the insulation on the pickup wire, so I need to resolder the copper wire back on to the pickup points before I know the pickup is working.
Do I have to strip the insulation from the copper wire somehow? There seems to be conflicting info on the internet. A Stewmac video showed just winding the copper wire through the hole a couple of times and then soldering - presumably the solder melts the wire insulation? Any tips would be gratefully received.
If you need to be more certain and it's a plastic bobbin, you can carefully scrape the coating off by running a knife blade along the wire with it held against the bobbin, but it's extremely easy to cut right through it.
There is an argument for using the damaged pickup as an excuse to upgrade to something better.
I suspect the pickup is properly borked anyway, but I think I'll just solder it without worrying about the coating and see what happens.
Connect the other end of the wire to the eyelet with a brief bit of heat.
