Wah woes
thomasw88thomasw88 Frets: 2320
Getting a really annoying crackle with my George Dennis wah   Doesn't matter what type of power i use and the leads are fine.
Have attached a quick sound file of it.
Any suggestions as to what it is or how to fix it?
https://wetransfer.com/downloads/c3942bf3416c1271b883bccd26ab0c3e20180928092646/2c0593add82d90703232f65dc4529e3d20180928092646/272702
  • ICBMICBM Frets: 72253
    Sounds like a failing component. It doesn't seem to be related to the wah sweep so it's probably not anything mechanical like a bad solder joint which would be affected by pressure on the pedal. What component exactly, I couldn't say - it might be a pain to locate as well.
    Looking at the schematic, there are two electrolytic (or tantalum) caps in the audio part of the circuit, C8 and C12. I would try changing them first and see what happens. After that, possibly the IC (MC33178).
    https://postimg.cc/Hj4fw98q
  • thomasw88thomasw88 Frets: 2320
    cheers ICBM.
